method to change
jm2rlp
method to change
What should I do so that the left right changes yaw and roll of control panel (remote contro)
- Contact:
Re: method to change
Welcome to the forum jm2rlp.
Are you using the Crazyflie python GUI client? If so, simply edit your controller configuration either in the GUI.
BTW, I moved this post to the Crazyflie->Support sub-forum as it is more appropriate.
