Hello everybody !
I am testing the latest CF2-firmware. I had twice the same problem: when I put the thrust level to 0, the motors continue to run some seconds ---> crash !
Is not it like the bug #69 ? I hope not.
Regards
Jean-Claude
Motorscontinue running
- Contact:
Re: Motorscontinue running
Hi Jean-Claude,
Do you get this error when flying with altitude hold or without?
Best regards,
Marcus
Best regards,
Marcus
Mitteau
As far as I know, it was not in AltHold mode.
Regards
Jean-Claude
Regards
Jean-Claude
- Contact:
Are you running the latest revision of the client/firmware or is it the latest release? We're working on pushing out a new release for the client, but the best would be if you could clone it from GitHub and test the latest revision and see if you still have the same issue.
Best regards,
Marcus
Best regards,
Marcus
Mitteau
Hi
I send you my quad (contact with Bjorn).
You will see.
Software versions are the latest: cfclient 2015 and firmware 2016-02.
Regards
Jean-Claude
You will see.
Regards
Jean-Claude
- Contact:
Ok we will have a look at it.
