Is the radio PA working on windows 10 laptops?
Radio dongle and windows10
- Contact:
Re: Radio dongle and windows10
Yes, I believe it does work on Windows 10. Don't quote me on that though... I'm not a Windows user.
jERRY
I have the same issue which the windows 10 can't detect the Crazyradio PA dongle, any suggestion??
Crazyradio works fine with Windows 10. Though it requires you to install the driver with zadig: https://wiki.bitcraze.io/doc:crazyradio ... dows_zadig.
Have you installed the driver and how do you see that the Crazyradio is not working, have you tried using it with the Crazyflie client?
jERRY
I have tried to run the Zadig for installing the Crazyradio driver, but the Zadig can't detect and display the USB ID on the Zadig UI,
There is no any "libusb(WinUSB) devices" item in the device manager, after I forced to install driver.
And
It'll show "Found 0 devices" after performed the Crazyflie client.
PC : Lenovo X1
OS : Windows 10 home 64
This has only happened in Lenovo@Win10, It works fine with Raspberry Pi2
Any suggest??
And
PC : Lenovo X1
Any suggest??
You can show all devices with Zadig (see the bottom of the page I sent you), the Crazyradio should be listed there.
