[SOLVED]Crazyflie no fly using bluetooth
HamSamwich
Post by HamSamwich »
Hi all,
I'm new here, just got a crazyflie 2.0. I did the self test then assembled it. Turn it on and I get the proper led pattern. Installed the crazy file client on both my Samsung galaxy 6 and Samsung galaxy tab 4. They both pair up to the crazyflie but then do nothing else. No movement in the props at all. Made sure the crazyflie was not jostled around while turning on. Don't know where to go from here, any suggestions?
HamSamwich
Re: Crazyflie no fly using bluetooth
I found the answer to my problem, it was listed in the wiki:
Make sure that you have not paired your phone with the Crazyflie 2.0 via your phone's general Bluetooth settings, otherwise the app will not be able to connect properly (connection will claim to be successful, but controls won't work)
This information was not listed in the tutorial so I am posting it here just in case someone else comes along with the same issue.
