How to learn firmware version crazyflie?
nurp
Post by nurp »
There was a question already but I couldn't find it. Also not in the FAQ.
Would you please write again how to learn the firmware version on my crazflie 2.0?
Thank you
nurp
Re: How to learn firmware version crazyflie?
Post by nurp »
It says in the client application documentation;
To check the firmware version, under the View menu, open up Tabs→Console tab and look at the output when connecting to the Crazyflie 1.0/2.0.
And I check the console tab, it prints this:
EXPBRD: Found 0 memories.
EEPROM: I2C connection [OK].
Status 0
AK8963: Self test [OK].
LPS25H: Self test [OK].
OW: Found 0.
SYS: Free heap: 5880 bytes
Is the version written to this output or did I misunderstand?
Post by chad »
It seems like some of your console output is missing... There should be a few lines above your top line, like this:
SYS: Build 58:2cad61d5f1a4 (2015.08.1-58) MODIFIED
SYS: I am 0x31343835313347012D0030 and I have 1024KB of flash!
CFGBLK: v1, verification [OK]
DECK_DRIVERS: Found 5 drivers
DECK_INFO: Found 0 deck memory.
DECK_CORE: 0 deck enumerated
SYS: Free heap: 5376 bytes
The line that reads: Build 58:2cad61d5f1a4 (2015.08.1-58) MODIFIED is your firmware version. Mine is a custom built firmware with changes not committed to the repository - hence it reads MODIFIED. If you use the latest released firmware, yours should look like this:
SYS: Build 0:61e23e51d7d3 (2015.08.1) CLEAN
proplane64
Post by proplane64 »
My console reads blank......
You can get the version in the about box as well, in help/about tab debug.
it should look like that:
Crazyflie
Connected: radio://0/94/2M
Firmware: 5383d70b2114 (MODIFIED)
