[SOLVED] cflib.Crazyflie: Resending for (76,1)
Danish20
Post by Danish20 »
I was using crazyflie 2.0 previously now I am trying to connect the crazyflie 1.0 with python client.
Its detecting but not connecting.
Is there any way to resolve without flashing the drone?
I want to run it with a python code I crated but it's not connecting. Crazyflie 2.0 was working fine.
now what should I do?
Thanks in advance
Reason: solved
Danish20
Re: cflib.Crazyflie: Resending for (76,1)
Post by Danish20 »
Ignore this , Somehow I dared to upgrade the firmware and it's not so hard or risky.
It's better yo upgrade the firmware
Post by chad »
Danish20 wrote:Ignore this , Somehow I dared to upgrade the firmware and it's not so hard or risky.
Glad you resolved this! Yes, it is easy and not dangerous to flash firmware on the Crazyflie. Crazyradio is just slightly riskier because you can brick it and must then use SPI to reflash but the Crazyflie (both 1 and 2) will not brick even with a bad flash. You can pretty much always get them back running if you flash a bad firmware.
