Crazyradio on Mac
luca0074
Crazyradio on Mac
Post by luca0074 »
The Program works but the Crazyradio seems not to work:
Bildschirmfoto 2013-05-14 um 19.30.51.png (10.34 KiB) Viewed 10193 times
What have I forgot to install on my Mac?
thank u very much for support!
greetings Luca
ps: when i use the VM the dongle is present and works... but i dont want to use a VM ;)
Re: Crazyradio on Mac
Have you tried the OSX install on the wiki?
I don't have a Mac so that's about how far I can help you.
zenocon
Post by zenocon »
Yes, same issue here. Mac OS (Mountain Lion) doesn't recognize the USB radio.
USBF:	75429.540	[0xffffff8048231200] The IOUSBFamily is having trouble enumerating a USB device that has been plugged in.  It will keep retrying.  (Port 1 of Hub at 0x14000000)
USBF:	75434.  5	[0xffffff8048231200] The IOUSBFamily was not able to enumerate a device.
Do I need to upgrade the firmware on the radio?
TheFrog4u
Post by TheFrog4u »
There is an issue with usb 3 ports on mac. Preferable use a usb 2 port if possible, otherwise you will have to update the firmware as dicribed in the wiki
