Crazyradio PA not picking up Crazyflie 2
accentronix
Post by accentronix »
I have a crazyflie 2 which works perfectly with my android device via bluetooth but I can not connect it the crazyflie to my pc via the Crazyradio PA. The Crazyradio PA drivers is installed but when I open the pc bitcrazy client and click on 'Connect' it does not pick up anything. When I click on 'Scan' it still does not pick up anything.
I am using a windows machine.
Is there an easy way to upgrade the Crazyradio PA firmware instead of by using python?
derf
Re: Crazyradio PA not picking up Crazyflie 2
Post by derf »
Which Windows version do you use?
What problems do you have with flashing the Crazyradio firmware using Python?
