Error during flash operation (err code -1)
skube
Post by skube »
I am trying to flash and I keep getting errors. I am trying with Verify Flashing option checked and it only goes a little before giving a status of verification failed! When I uncheck Verify Flashing and simply hit program (with .bin file) I get the following status "Error during flash operation (err code -1)". I am trying to use a Macbook running the CFClient and it seems very flakey.
Crazyflie Nano 10-DOF | AR Drone v1 | MikroKopter Okto
Re: Error during flash operation (err code -1)
Hmmm, can you elaborate a bit more? No problem connecting to the bootloader? What client version are you using? The flashing stops in the middle of the process (progress bar in the middle)?
Normaly it is not necessary to do a verification as everything sent is CRC checked so if the flashing finishes it is OK.
skube
Post by skube »
Well I was using the latest client version on a Macbook. I just tried on a PC and it seemed to go better, but looking at the console I see the following output for my CF (DOF-6):
ng!
SYS: I am 0x8722214853568549675FF54 and I have 128KB of flash!
IMU: HMC5883L I2C connection [FAIL].
IMU: MS5611 I2C connection [FAIL].
MPU6050: Self test [OK].
I just updated the firmware on another fresh CF (DOF-10) and it went much better:
ng!
SYS: Build 26:5f65b66e004d (Production-V2) CLEAN
SYS: I am 0x871231165456854966EFF50 and I have 128KB of flash!
HMC5883L: Self test [OK].
MS5611: Self test [OK].
So I'm thinking something is wrong with the DOF-6 right out of the box?
OK, then there might be an issue related to MAC. I will file a bug report.
The 6-DOF output is accually correct. To avoid having two different firmwares for the 6-DOF and the 10-DOF the firmware checks for availible sensors. In the 6-DOF case it can't find the magnetometer and the barometer, not mounted, and therefore fails. It might look a bit strange but it is a lot better then having two different firmwares. ;)
skube
Post by skube »
Ah OK. That makes sense. Thanks tobias.
Hi skube,
Could you paste the output from the console when you get this error?
Could you try to pull out and re-insert the Crazyradio and see if that helps?
/Marcus
