Can't bootload crazyflie 2.0
swapnilrs
Post by swapnilrs »
I'm trying to bootload crazyflie 2.0 but the client can't bootload the crazyflie 2.0 but it can bootload 1.0. The Configure 2.0 has been grade out and is not available for 2014.12.3 PC client
I'm using https://github.com/bitcraze/crazyflie-c ... /2014.12.3 PC client.
I aslo followed:
The procedure to put the CF2 in bootloading is a bit different from CF1. You should hold down the power button until the blue LED M2 starts to blink. Release it and the blue led M3 should also start blinking. The CF2 is now in "radio" bootloader mode. Now you should be able to connect to it in the bootloader dialog.
Can anyone help.
Re: Can't bootload crazyflie 2.0
the screen to bootload Crazyflie 1 and 2 is the same. Put your Crazyflie 2 in bootloader mode and click 'cold-boot' and it should work.
swapnilrs
Post by swapnilrs »
I could update the recent firmware to crazyflie 2.0 but I can't configure Radio channels and Radio Bandwidth for 2.0 as Configure 2.0 option under Crazyflie is grayed out(disabled).
To configure Crazyflie 2.0 you should first connect to it, then the box will be accessible.
swapnilrs
Post by swapnilrs »
Thanks its working now :)
