[SOLVED] CrazyFlie App
chapeshiel
Im connecting over Bluetooth and the app says its connecting but I get no response from the copter. Also when I used to be able to connect, the icon for saying it was connected was highlighted blue but now it is green when it says it is connected if this helps at all.
Reason: solved
Reason: solved
derf
Re: CrazyFlie App
I guess you are referring to the Android app?
So it has worked before, but now it does not work anymore? What has changed? Did you update your phone, etc?
Which version of the app are you running?
The button should only be green when it's connected to the Crazyflie via the Crazyradio USB dongle.
If that is not the case, then it's probably a bug.
Regards,
Fred
Regards,
Fred
chapeshiel
Re: CrazyFlie App
I'm stupid... There was a bug with my phone and bluetooth connectivity. I simply erased the crazyflie from the bluetooth settings and then reconnected. Anyways, thanks for the help!
derf
Re: CrazyFlie App
Np. I'm glad you found the error and it's working again.
