Hello All,
I just downloaded the "cfclient-2014.01.0" and update the CF with "Crazyflie_2014.01.0.bin" firmware but I saw that in the cfclient are not available the "function" Plotter.
could you please explain me why it is not available?
thanks
Thomas
[SOLVED] Plotter on "cfclient-2014.01.0"
thomas_pittin
Re: Plotter on "cfclient-2014.01.0"
It is probably the pyQtGraph lib that is not installed. Did you check the client readme?
thomas_pittin
I'm on Linux Ubuntu 15.04, how can I install the library pyQtGraph?
thanks
Thomas
thanks
Thomas
thomas_pittin
I found the solution, I download the library.deb and now I can see the Plotter on CFclient
- Contact:
I've marked the original thread "solved."
