Initial Power On self test failure ?
okcfam
Post by okcfam »
This is at the first use and running self test as part of the build.
On the initial power the m2/m3 leds turn on solid blue and m4 flashes green for part of a second.
m1 flashes red constantly at about once per second.
Is this a failure ?
Thanks,
Steve A
0x746821
Re: Initial Power On self test failure ?
Post by 0x746821 »
A very good description of the self-test can be found here:
https://www.bitcraze.io/getting-started ... -0/#tesing
If the M4 LED blinks GREEN five times fast, then the test has passed.
If the self-test fails, then the M1 LED blink 5 times fast RED, then pauses and does it again.
Here is also a description of the leds:
https://wiki.bitcraze.io/projects:crazy ... uide:index
Hope that helps,
Tom
