Unable to charge while CF2 is off and Green LED issues
toysldr
Post by toysldr »
Shouldn't I be able to charge the CF2 by USB when it's powered off? Also, reading the intro manual, shouldn't the green LED flash when it's charging? Right now the blue LED flashes when it's charging.
Here is a copy of the log file from the connection:
SYS: Build 0:29624e7f6e3b (2014.12.1) CLEAN
SYS: I am 0x31343835313347042Bh!
EXPBRD: Found 0 memories.
Status 0
EEPROM: I2C connection [OK].
Status 0
AK8963: Self test [OK].
LPS25H: Self test [OK].
OW: Found 0.
SYS: Free heap: 5768 bytes
derf
Re: Unable to charge while CF2 is off and Green LED issues
Post by derf »
As far as I know, the CF2 is only charged, when it's powered on (@bitcraze team, please correct me if I'm wrong!).
Blue LED flashing while charging is correct (see https://wiki.bitcraze.io/projects:crazy ... uide:index).
toysldr
Post by toysldr »
Well crap, I read differently somewhere. Thanks for the correction! Now to figure out this FPV stuff =)
