Problem to take off(battery problem. ?)
Prashant
Post by Prashant »
Hi
I received new crazyfile 2.0 .. assembled it...VM up and running. ..ps3 controlled..yesterday all was well...now when I give command via ps3 controller crazyfile shut off....when I start self test is done. ..I connected crazyfile to power supply and gave command it doesn't shut off...is it a battery issue.?
Prashant
Re: Problem to take off(battery problem. ?)
Post by Prashant »
Got it running
Post by chad »
Prashant wrote:Hi
Happy to hear you got it running. Can you post back what you did so that you might help other in your situation..? Did you simply upgrade the firmware? The shut-off issue you write about sounds like something that was solved a while ago...
