Cfclient can't find any radio dongle
panda
Post by panda »
I am on Archlinux, trying to use cfclient to connect to my CrazyFlie 2.0, using my CrazyRadio PA dongle. I followed the wiki instructions to install cfclient, but it simply doesn't find any CrazyRadio dongle (I get the error "Cannot find a Crazyradio Dongle" if I go to Crazyflie > Bootloader and click on Initialize).
I have configured the udev rules properly, and even if I run sudo cfclient, it doesn't find any dongle. I can however put the dongle on bootloader mode and I have upgraded its firmware to the latest, but yet, cfclient simply can't find any. This is the output from lsusb -d 1915:7777 -v :
Bus 002 Device 023: ID 1915:7777 Nordic Semiconductor ASA
Couldn't open device, some information will be missing
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x1915 Nordic Semiconductor ASA
  idProduct          0x7777
  bcdDevice           99.53
  iManufacturer           1
  iProduct                2
  iSerial                29
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           32
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              100mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceSubClass    255 Vendor Specific Subclass
      bInterfaceProtocol      0
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               6
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x01  EP 1 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               6
It is plugged to a USB 2.0 port. How can I get this to work?
Re: Cfclient can't find any radio dongle
Post by chad »
Are you running Archlinux natively or in a VM? If it is a VM, what's the host OS?
Have you tried running the client with sudo? I'm guessing there still is some problem with permissions.
panda
Post by panda »
I am running natively and as I wrote in my first post, I have tried running it with sudo. It still doesn't work.
It has been many weeks now, can you please help me out? What could be the problem?
derf
Post by derf »
Have you tried using the Crazyradio on a different machine, different OS (e.g. Windows, Android)?
