Hi all,
I've found that there is also USB interface support on crazyflie 2.0 with d+ and d- connectors. But there is already some kind of use of this interface? Or what can be potential uses?
Thank you!
[SOLVED] USB connection to Crazyflie
- Contact:
Re: USB connection to Crazyflie
Yes, you can use USB to connect to the Crazyflie 2.0 instead of the Crazyradio or Bluetooth LE. It's useful for getting higher bandwidth of you want to log large amounts of data and also you can start the STM32F4 in DFU mode to allow firmware upgrades (these can also be done wireless with the Crazyradio).
