M2 Led fully lit... Seems not working
Charliemr99
Post by Charliemr99 »
I just bought the crazyflie 2.0, I did the assembling perfectly, but when I connected my iPhone to the CF, after 3 min, it turned off. After charging the CF, when I turn it on, only the M2 led is fully lit and the rest are off. What can I do? How can I reset the CF?
With battery and without it, is the same. Only M2 LED is on
Re: M2 Led fully lit... Seems not working
This could be caused by software. Could you try the following and see if it helps?
  • Make sure the Crazyflie is fully charged
  • Remove the battery and plug it in again
  • Try to turn the power on/off using the button a couple of times (if it doesn't start up correctly)
ericson
Post by ericson »
Same issue for me.
I upgraded the firmware, following the procedures (https://bitbucket.org/bitcraze/crazyfli ... 4.01.0.bin)
Since then, M2 Led fully lit when CF turned on, nothing else.
I tried with other batteries, unplugging / plugging it, trying multiple times.
Any idea please?
ericson
Post by ericson »
as far as I'm concerned, problem solved: I downgraded my CF...
