M1 and M3 motors are not working on launching
kote
I assembled the quadcopter following the instructions and now I tried to turn it on see if it's working. I can see that 2 blue lights are on, the green light blinked 5 times and red light blinks 2hz. According to instructions, it means the quancopter passed the test and is ready to fly. However, I've noticed only 2 out of 4 motors spin on launch and I am not sure why other 2 are not working. Can it be the problem with soldering?
- Contact:
Re: M1 and M3 motors are not working on launching
HI,
Could you please check so you haven't attached the propellers too tightly onto the motors?
Could you please try the following?
- Fully charge the Crazyflie 2.0 using USB
- Unplug the Crazyflie 2.0 and turn it off
- Place the Crazyflie 2.0 on a stable surface that is level and power it on
- All four motors should now spin, one after the other one (like this
