Hi team,
I have seen other threads on the same issue ...
my brand new crazyflie 2.0 from seeedstudio has i2c error 1024 with lps25H sensor.
I have contacted their support but no answer for now... can you help me to get a new cpu board ?
(btw, it flights with custom firmware and sensor disabled, but this is for edu. and I need fully functional copter)
regards
raph
SYS: Build 0:29624e7f6e3b (2014.12.1) CLEAN
SYS: I am 0x313238323133470439003C and I have 1024KB of flash!
EXPBRD: Found 0 memories.
EEPROM: I2C connection [OK].
AK8963: Self test [OK].
OW: Found 0.
Status 0
Status 0
crazyflie 2.0 pressure sensor issue
raph38130
- Contact:
Re: crazyflie 2.0 pressure sensor issue
Moved to Crazyflie Nano Quadcopter->Support since it's more applicable and might get better visibility.
raph38130
up !
how to get replacement unit ? seeedstudio does not answer to my inquiries ...
- Contact:
You might want to to try to contact the Bitcraze guys at the email here under the "Contact" section. They are frequently on the forum but often they are quite busy and emailing them might get a faster response on how you should proceed. It's probably good to reference this thread in your email so they have access to your console log output.
