pygame + hg + OS X
jamisnemo
pygame + hg + OS X
Post by jamisnemo »
So, in the OS X section of this wiki article http://wiki.bitcraze.se/projects:crazyf ... ls:install, there is this line:
As of 2013-05-08 the non-hg doesn't build correctly with brew installed SDL.
Is this an SDL issue, a pygame issue, or a Brew issue?
Regardless, has anyone gotten past this?
Thanks for the help! I'll continue looking into it as well...
jamisnemo
Re: pygame + hg + OS X
Post by jamisnemo »
Well it looks like we need to install mercurial before we can try to install pygame.
I had to do:
brew install mercurial
before I could do:
pip install hg+http://bitbucket.org/pygame/pygame
This gets pygame and with all of the rest of the requirements installed you can then start the python client...
But the client can't connect to the Crazyflie. It seems like the Crazyradio doesn't support OS X yet??
jamisnemo
Post by jamisnemo »
Oh! This post says I need a controller connected first: http://forum.bitcraze.se/viewtopic.php? ... t=OSx#p658
Okay! Time to head to Best Buy...
jamisnemo wrote:But the client can't connect to the Crazyflie. It seems like the Crazyradio doesn't support OS X yet??
Does you computer only have USB3 ports? If not could you connect the Crazyradio to a USB2 port? It's should possible to connect to the Crazyflie without having a controller plugged in (although the issue you mentioned might affect this on OSX).
/Marcus
smiler
Post by smiler »
jamisnemo wrote:So, in the OS X section of this wiki article http://wiki.bitcraze.se/projects:crazyf ... ls:install, there is this line:
It's a pygame issue, fixed in the HG repository but hasn't found its way into the release version yet.
I'm currently working on building a native OSX package of the client, similar to the windows one using py2app.
smiler wrote:I'm currently working on building a native OSX package of the client, similar to the windows one using py2app.
That would be great!! I guess for packaging it OSX is needed?
/Marcus
smiler
Post by smiler »
marcus wrote: That would be great!! I guess for packaging it OSX is needed?
I don't know (yet). Native binaries are needed but I guess you in theory can set up a cross compiler for it. However my python-fu isn't very good (I'm more of a ruby guy :)). We'll see.
