Hi there! I import the Bitcraze virtual machine0.6 into the vm player.then install the VMtools.
whilst typing "su" in the terminal ,I need type the password.I have tried the "crazyflie",but It dosn't work.
What's the password? please kind tell me,TY!
can't get the SU permission of VM0.6 in virtual machine
mingming254
Slaxx
- Member
Re: can't get the SU permission of VM0.6 in virtual machine
probably still american layout on the keyboard?
mingming254
YES,it's american layout. How can i type the correct password? Thanks for your reply.
Slaxx
- Member
Well I don't know what layout you have on your keyboard. I for example had to put in Crayzflie since on my keyboard y and z are changed.
But you can also just change the keyboard settings to your layout and then it should be no problem.
mingming254
TY.The problem have been solved.It's my first time to use ubantu.
I type the wrong command line.what i should type is "sudo su",not "su".
The password is "crazyflie".
