Hi everyone,
I am trying to run Python examples from Windows machine, and it seems that none of them are able to connect to the quad:
Crazyflies found:
radio://0/10/250K
Connecting to radio://0/10/250K
Is what I get. Then after a while the quad turns off. I can connect to the quad using the GUI just fine. I've attached a log file with logging set to DEBUG. Any help will be greatly appreciated!
Cannot Connect to Quad via Python Script
JusticeForAll
- Attachments
- basiclog.log
- (39.35 KiB) Downloaded 302 times
- Contact:
Re: Cannot Connect to Quad via Python Script
Is it the same version of the client repo you are using to connect to the Crazyflie in both instances?
What version of the Crazyflie do you have? I would recommend upgrading to the latest version of the firmware and the client. Looking at the log it sees as if you are trying to connect to a Crazyflie 1.0 with older firmware. The client is trying to download information about the memories available, which the old firmware doesn't support and won't reply to. Upgrading should fix this.
JusticeForAll
Installed new firmware and it worked!
Thank you!
Thank you!
