Print the acceloration values
whjrtss
Post by whjrtss »
Hi. I have a question.
Bin file (Crazyflie Firmware) has accel value x,y,z, but CF Client don't have them.
Example, Stabilizer.roll is a value from gyro sensor. but client files has no any keyword about accel.
I think, 'Firmware have accel values, but Python client has no module(?) or code what printing values.'
May I know about packet communication?...
'Logbasic.py' in 'Examples' have roll,pitch,yaw values.
I hope to see accel and baro values. I don't know make the code for this operation.
Thank you for reply.
Re: Print the acceloration values
These are defined and communicated using the Log subsystem (http://wiki.bitcraze.se/projects:crazyflie:firmware:log). You can see all exported variable using view/tab/"Log TOC". There is log variables for the accelerometer already setup. Using Settings/"logging configuration" you can configure a new log block that can be displayed in the plotter in the GUI and can also be recorded in a CSV file. You can also go to view/tabs/Log Blocks to see the log blocks already setup and record any of them in a file. The logs are saved in the config folder/log (can be open with the menu settings/Open config folder).
This log subsystem is designed to make it easy to get variable value at regular interval, the minimum reachable interval is 10ms (100 readings per seconds).
