Help threading basiclog
GeEom
Post by GeEom »
Hello everyone!
I've been trying to interface the crazyflie 2.0 with other software.
To begin with I've tried to thread the basiclog example script. I want to store incoming 'flie data in one thread, allowing the main thread to display/pass on/work with the data in real time.
At present the main returning is ending my thread, halting the crazyflie communication. A simple sleep loop propping open the main does not destroy the thread, but does defeat its purpose.
Whilst I'm not experienced in python, I've made a simple numeric calculation persist in a nondaemon thread beyond the main, and then referenced its output. This leads me to believe that there is something in the crazyflie libraries interfering with me.
Any insight would be much appreciated!
My code follows, it's a simple variant of basiclog.py from the client examples
import sys
sys.path.append("C:\Users\David\Desktop\crazyflie-clients-python\lib")
import cflib.crtp
print "Scan found:"
for i in available:
    print i[0]
import threading, Queue, time, logging
from threading import Thread
from threading import Timer
from cfclient.utils.logconfigreader import LogConfig
queue = Queue.Queue(1)
class LoggingExample(threading.Thread):
    def __init__(self, link_uri):
        super(LoggingExample, self).__init__()
        self.daemon = False
        global queue
        import sys
        import threading, Queue, time, logging, cflib.crtp
        self._cf = Crazyflie()
        self._cf.connected.add_callback(self._connected)
        self._cf.disconnected.add_callback(self._disconnected)
        self._cf.connection_failed.add_callback(self._connection_failed)
        self._cf.open_link(link_uri)
        self.is_connected = True
        self._lg_stab = LogConfig(name="Stabilizer", period_in_ms=10)
        self._lg_stab.add_variable("stabilizer.roll", "float")
        self._lg_stab.add_variable("stabilizer.pitch", "float")
        self._lg_stab.add_variable("stabilizer.yaw", "float")
        self._cf.log.add_config(self._lg_stab)
        if self._lg_stab.valid:
            self._lg_stab.data_received_cb.add_callback(self._stab_log_data)
            self._lg_stab.start()
    def _stab_log_data(self, timestamp, data, logconf):
        try:
            task = queue.put("[%d][%s]: %s" % (timestamp, logconf.name, data),False)
            queue.task_done()
        except Queue.Full:
            pass
    def _connection_failed(self, link_uri, msg):
        self.is_connected = False
    def _disconnected(self, link_uri):
LoggingExample(available[0][0])
Re: Help threading basiclog
The crayflie lib launches a brunch of threads in the background and all of them are marked as "daemon", this means that you have to keep at least one non-deamon thread alive, sleeping can actually be a viable solution sometime.
The log callbacks are called from the packet dispatcher thread. So it means that you should not lock in a callback but writing to file should be ok. In your example the function _stab_log_data is not run from your thread but from the packet dispatcher thread.
For example you can look in the zmq server we made recently: https://github.com/bitcraze/crazyflie-c ... b/cfzmq.py, it stays alive thanks to 2 threads that have "while True:" in there run function. By the way this zmq server is made allow easy communication with third party software so it could be interesting for you.
I hope I answered your question.
BR
Arnaud
qubitter
Post by qubitter »
I'm trying to get the API set up on my MacBook Air 2014 and I keep getting the error that I am missing the Queue module. The script is just an order to import all of crtp and this is what I get:
File "/Users/me/Documents/cflibim.py", line 1, in <module>
from cflib import crtp
File "/Library/Frameworks/Python.framework/Versions/3.4/lib/python3.4/site-packages/cflib/crtp/__init__.py", line 38, in <module>
from .radiodriver import RadioDriver
File "/Library/Frameworks/Python.framework/Versions/3.4/lib/python3.4/site-packages/cflib/crtp/radiodriver.py", line 46, in <module>
import Queue
ImportError: No module named 'Queue
This is the error code from IDLE. Please help! :(
whoenig
Post by whoenig »
The official SDK uses Python 2.7.x. You can install python2 besides python3 and use python2 instead of python3.
Python3 changed a bunch of things in a non-compatible way. In this case they renamed Queue to queue (i.e. lowercase). I would expect that there are more such issues in the code, hence it is easier to just use python2 instead.
