Configure Device Mapping - Save greyed out
skube
Post by skube »
I'm trying to setup a new profile under the Configure Input Device option, but I can't save any new profile because the Save button is always greyed out. I'm using a Xbox 360 on Win 7. Is there something I'm doing wrong?
Input device configuration_2013-05-09_08-31-13.png (33.11 KiB) Viewed 5225 times
Crazyflie Nano 10-DOF | AR Drone v1 | MikroKopter Okto
jweather
Re: Configure Device Mapping - Save greyed out
Post by jweather »
You have to select an axis or button for all of the inputs, including trim +/-, killswitch, and exit app before it will let you save the config currently.
skube
Post by skube »
Ah. Thanks jweather! That's not very obvious.
Also, with the Xbox controller, you run out of buttons to map to, since the digtal pad doesn't work right now. I guess this will be fixed at a later date.
skube wrote:Also, with the Xbox controller, you run out of buttons to map to, since the digtal pad doesn't work right now. I guess this will be fixed at a later date.
Yeah, we have a few issues for this. Hopefully all of them will be fixed in the next version.
Only digital buttons supported for trim
Should not require trim/estop/exit to save config
/Marcus
