LED-Ring expansion board not found
Nyothan
Post by Nyothan »
Hi everybody,
I have the known issue with the bad soldered IMU, which leads the crazyflie to fail its self-test.
Even if it can't fly, I would like to play with the LED ring expansion by adding new effects in neopixelring.c. The problem is that
The LED-Ring expansion board is not detected when the expbrd module is called: It says "EXPBRD: Found 0 memories".
Here is the complete log:
SYS: Build 0:1ab92e55c44b (2014.12.0) CLEAN
SYS: I am 0x313238323133470D31002B and I have 1024KB of flash!
AIL].
EXPBRD: Found 0 memories.
EEPROM: I2C connection [OK].
OW: Found 0.
Status 0
Status 0
I would like to know if the fact that the IMU fails to initialize can have an impact on the fact that the LED Ring expansion board
is not detected.
Nyothan
Re: LED-Ring expansion board not found
Post by Nyothan »
Any idea?
poizone
Post by poizone »
I see no where on the schematic that links the IMU and expansion header. I would assume that this is the result of you attempting to work in the zone of Undefined Behavior after a failed test. While continuing to work after failure occurs during flight should be a goal, this is what I would consider the expected behavior when a failure occurs before flight.
Disable your IMU and IMU test in firmware and see if it works.
The system doesn't start when a test has failed. You can comment the stababilizer test to make it pass.
Nyothan
Post by Nyothan »
I commented the 'stabilizerTest()' line in system.c, but the LED Ring is still not detected.
Here is the console output:
SYS: Build 31+:1781d07675cf (2014.12.0) MODIFIED
OW: Found 0.
SYS: Free heap: 6048 bytes
If I am right, it's the call to 'expbrdInit()' which tries to detect if an expansion board is connected. But it prints 'EXPBRD: Found 0 memories'...
Post by chad »
Nyothan wrote:I commented the 'stabilizerTest()' line in system.c, but the LED Ring is still not detected.
Have you installed the board on the top of the Crazyflie or the bottom? It only works with a bottom install.
