I have the known issue with the bad soldered IMU, which leads the crazyflie to fail its self-test.
Even if it can't fly, I would like to play with the LED ring expansion by adding new effects in neopixelring.c. The problem is that
The LED-Ring expansion board is not detected when the expbrd module is called: It says "EXPBRD: Found 0 memories".
Here is the complete log:
SYS: Crazyflie is up and running!
SYS: Build 0:1ab92e55c44b (2014.12.0) CLEAN
SYS: I am 0x313238323133470D31002B and I have 1024KB of flash!
I2CDEV: Error callback nr: 1024
AIL].
IMU: AK8963 I2C connection [FAIL].
IMU: LPS25H I2C connection [FAIL].
EXPBRD: Found 0 memories.
EEPROM: I2C connection [OK].
OW: Found 0.
30 78 42 43 0 50 0 0 0 0 0 0 0 0 0 7D
Status 0
Status 0is not detected.
