small error in the Modifying the Raspian... wiki entry
Solek
when ceating the start_cfheadless file you are still in /home/bitcraze/projects/ took me a while to realise that i had to change directory to /home/bitcraze/ first because it is not standing in the guide
- Contact:
Re: small error in the Modifying the Raspian... wiki entry
Thanks for raising awareness about that!
You're talking about this Modifying the Raspbian Wheezy image page, right? I just added a 'cd' at the top of the section where you create the start_cfheadless file. That should make things more smooth (and clear).
Cheers!
Cheers!
miodek1987
Interesting stuff. Learned a lot from it. Thanks:)
