[SOLVED] Crazyflie 2.0 flashes red, IMU: LPS25H Fail
chromebookbob
Post by chromebookbob »
SYS: Build 0:1ab92e55c44b (2014.12.0) CLEAN
003B and I have 1024KB of flash!
EXPBRD: Found 0 memories.
EEPROM: I2C connection [OK].
AK8963: Self test [OK].
OW: Found 0.
Status 0
Status 0
I just turned on my crazyflie today, it self-tested and connected to my pc, but there is a red flashing light on it and it won't fly. Any help would be appreciated. I have tried tapping it as per the troubleshooting guide, I don't really understand what is going on.
Last edited by chromebookbob on Sun Feb 22, 2015 10:27 am, edited 1 time in total.
Re: Crazyflie 2.0 flashes red, IMU: LPS25H Fail
Something happened with the pressure sensor chip, probably soldering that has gone bad. You can contact Seeedstudio support to get it fixed. I have also attached a firmware that disables the pressure sensor functionality so it will work again without it (altitude hold will not work).
cf2 2014.12.0-17 - No pressure.dfu
Dfu file to be flashed with USB.
(74.21 KiB) Downloaded 512 times
cf2 2014.12.0-17 - No pressure.bin
Bin firmware to be flashed with Crazyradio
(73.91 KiB) Downloaded 598 times
chromebookbob
Thanks so much, I have contacted seeedstudio.com, but the firmware is just what I need in the meantime. I can keep working without the pressure sensor. Thanks again
qubitter
Re: [SOLVED] Crazyflie 2.0 flashes red, IMU: LPS25H Fail
Post by qubitter »
I have the same issue. Will the new board cost me anything?
No it wont as it is a manufacturing error, I sent you a PM.
