Hi Guys,
I'm looking take the baro out of the self test im my firmware as it has an I2C fault. Anyone seen the selftest code and could help me find it?
Thanks,
Where is the self test?
CrazyGuy
Re: Where is the self test?
hal/src/imu.c
There should be somewhere this code
So remove at the beginning of the file this line: #define IMU_ENABLE_PRESSURE_MS5611
I didn't test it but I think it will work
hal/src/imu.c
#ifdef IMU_ENABLE_PRESSURE_MS5611
if (ms5611Init(I2C1) == TRUE)
isMs5611Present = TRUE;
DEBUG_PRINT("MS5611 I2C connection [OK].\n");
else
DEBUG_PRINT("MS5611 I2C connection [FAIL].\n");
#endif
Call_me_a_Cab
- Member
Thanks dude!
