Hi all,
I am having trouble to connect to my CF 2 bootloader. I tried the following steps here:
http://wiki.bitcraze.se/doc:crazyflie:c ... tion_block
which are
1) power off
2) poweron button for 3 sec (blue leds are flashing alternately)
3) click "initiate bootloader coldboot"
I get status: trying to connect cold bootloader......
Then it timesout. I tried several permutations of the steps but to no avail...radio works cause I can connect normally.
[SOLVED] CF 2.0 can not connect to bootloader
oggy
oggy
Re: CF 2.0 can not connect to bootloader
solved this by using an updated version of the cfclient. For the sake of those stumbling on the same issue the latest cfclient is here:
https://github.com/bitcraze/crazyflie-c ... n/releases
