Does anyone know how to connect with the wifi on the Bitcraze VM?
I have already edited, added, and then created a new connection, but the VM doesn't look for the wifi available, it just try to connect through the "Wired connection 1"...
[SOLVED] VM Bitcraze Wifi
Call_me_a_Cab
- Member
Re: VM Bitcraze Wifi
I believe the VM will see the host WiFi as a wired connection once it's on the guest side.
Try to get connection by looking at the "wired 1" rather than creating a wireless one
By default the VM will be configured with a "nat" wired network so if the host machine has internet the virtual machine will have internet via a virtual wired connection.
Do you have a firewall that blocks virtualbox internet connectivity on public network? (this is the default windows firewall settings).
danielbpc
Thank you a lot, it was a problem with the firewall, but it is working now!
- Contact:
Re: [SOLVED] VM Bitcraze Wifi
Hi! I marked this topic [SOLVED] and moved it to the Crazyflie->Support sub-forum.
