I am trying to install the BitCraze VM on my Mac (OS X Yosemite 10.10), but I am facing some problems. I am using the VMware Fusion 7 and following the tutorial http://crazyflie.ecsiii.com/archives/2-Preparation.html and I already have the file "Bitcraze_VM_0.5.ova" dowloaded.
After step 6, an unexpected error occur: "System error: std::exception" and then "The operation could not be completed. No other information is available about the problem.".
Does anyone know what should I do?
BitCraze VM installation Error
danielbpc
Re: BitCraze VM installation Error
I downloaded the version 6 and it worked.
- Contact:
Definitely VM 0.6 is the one you should be using if you're working with the Crazyflie 2.0. I'm not sure why you got the error during the VM conversion but I'm going to try and replicate it myself.
I've also moved this topic to the Crazyflie->Support sub-forum.
