I just bought the LED-Ring and I know I plugged in properly. In the Client software, the detected board is greyed out. Am I missing something here ? I even flashed my 2.0 with the latest firmware. I am running the client on OS X.
It would be nice to be able to run the "RealFlight" Futaba controller with the Client software. It is detected on the OS X.
Thanks.
[SOLVED] LED-Ring not detected in Client software
kahuna001
Re: LED-Ring not detected in Client software
If you look at the console output tab in the cfclient after a boot does it output something like "EXPBRD: Found 1 board"?
kahuna001
It was a bad board. I got another one and it has been working fine until I updated the python client software. Now I don't even have the tab to select the LEDs anymore. This is the console output. It found the board.
SYS: Build 0:1ab92e55c44b (2014.12.0) CLEAN
SYS: I am 0x37333632313347032A0026 and I have 1024KB of flash!
EXPBRD: Found 1 memories.
EXPBRD: Info board 0:
-Header:EB
-Pins :0x8000
-Vid :BC
-Pid :1
-crc :23
EEPROM: I2C connection [OK].
AK8963: Self test [OK].
LPS25H: Self test [OK].
OW: Found 1.
OW: Serial 0xD 3E CB 8 0 0 0 88.
SYS: Free heap: 5872 bytes
-Header:EB
-Pins :0x8000
-Vid :BC
-Pid :1
-crc :23
OW: Found 1.
kahuna001
SOLVE Re: LED-Ring not detected in Client software
SOLVED..
Must be the codes I download and merged. I deleted everything and downloaded fresh and now I have all the tabs including ALT1 and ALT2.
