PC client help
Psichosix
PC client help
Post by Psichosix »
I posted on the blog then realized this was probably a much wider spot.
ok can someone help? I understand the LED additions have been implemented in the client. However how do I make a windows installer or run the client with the new changes? Also, if possible I remember seeing controller mappings for LED changes if that can be done also.
I saw the instructions in the read me but for the life of me, which is normally good with tech, I cannot manage to get this.
Re: PC client help
Hi Psichosix,
You need to be able to run the client from source, this is explained in the readme. I started a wiki page to explain maybe a bit more how to get going: http://wiki.bitcraze.se/doc:crazyflie:dev:env:python
As for generating the installer you can look in the win32install folder there is a readme that explains the procedure: https://github.com/bitcraze/crazyflie-c ... n32install
If you just want to run the latest client you do not need to generate an installer though.
