Log file location
hdmathias
- Member
Log file location
When logging via the Log Blocks tab in the PC Client and checking Write to File for the desired values, where is the log file written on a Windows system? I've searched the forum but don't see reference to where the resulting file lives. Thanks.
Re: Log file location
Hi hdmathias,
This functionality will write a csv file in the conf folder in logdata. You can access the conf folder with the menu "Settings/Open config folder"
For example I just run the stabilizer log and I got this files "logdata/20150127T10-22-43/Stabilizer-20150127T10-25-28.csv"
That contains (the timestamp is in miliseconds from startup):
Timestamp,stabilizer.roll,stabilizer.pitch,stabilizer.yaw
555043,-3.53916192055,5.90701341629,82.4352798462
555063,-3.53966760635,5.90694046021,82.4322814941
555083,-3.54133582115,5.9066362381,82.4277801514
555103,-3.53979253769,5.90455532074,82.4251556396
555123,-3.53908133507,5.90452241898,82.4208908081-
hdmathias
- Member
I knew it was there somewhere. Thanks very much, Arnaud.
