Hi everyone !
Did someone try the artoo library ? http://artoo.io/documentation/drivers/crazyflie/
Is it working fine with the crazyflie 2.0 ? the autonomous navigation really works ?
I was not able to find information about it.
Thanks !
Artoo library
Re: Artoo library
The library should not be able to fly it "autonomously" in the sense that you can tell it to go 1 meter forward etc. You can tell it to apply piloting commands, pitch, roll, yaw and trust. You can also script this so that the Crazyflie can fly "paths" but they will be different every time since it does not contain any position sensors.
