CF 2.0 unexpectedly turns off [SOLVED]
edelrabe
Post by edelrabe »
Hello, I use CF 2.0 with Crazyradio PA with gamepad controll. Very often CF turns off when I try to increase thrust from a ground. It happens time to time, most of all when I increase thrust deeply (I control it in a normal flight mode).
Then I need to manually turn it on and the bug may or may not repeats again. I didn't catch the bug when the CF in the air.
Crazyflie PC Clien reports that the battery is fully charged (>4000mA), link quality is fine, I don't see error in console.
The same bug I see when I control CF with Crazyradio PA on Android app.
Maybe I missed something? What can I check and fix to avoid this?
Re: CF 2.0 unexpectedly turns off
Post by chad »
Hi! The problem you're experiencing is fixed in a Crazyflie firmware update. Also checkout the wiki page about direct firmware update for info about the DFU procedure, if you don't use the Crazyradio to update the firmware.
edelrabe
Post by edelrabe »
Oh, great! Thanks, chad.
