Hello i receive my Crazyflie 2.0.
Im using Windows 8.1 as operating system.
No lucky to connect, i alredy installed all drivers (from zigzad) and download the lasted crazyflie for Windows from https://github.com/bitcraze/crazyflie-c ... n/releases
Any ideas ?
Windows 8.1 supported by the client ?
sub7
Re: Windows 8.1 supported by the client ?
no problem with 8.1
- Crazyflie power on
- usb crazyradio on your 8.1
- scan and connect
Can you see in your hardware management ethe crazyradio PA ?
- scan and connect
rebit
- Member
- Contact:
When you scan does the red LED light up on the Crazyradio? Can you start up the application, scan for a Crazyflie and then cut and paste all the console output here?
rebit
- Member
ok i will do this !
rebit
- Member
here the last log window
sub7
Can you put a picture of your cf when you try to connect the radio ?
- Contact:
The driver that's installed for the Crazyradio seems to be the wrong one. It should be libusb-win32 or libusbK, not WinUSB. Looking at the screenshot you posted it seems as if you installed the WinUSB driver. Have a look at the instructions on the Wiki and re-install the driver.
