[SOLVED] py2exe error when trying to build Windows installer
MitchMan
Post by MitchMan »
I am having a problem when I try to build any repository of cfclient (including 2014.12.1) into a Windows installer/exe. All pre-requisites from the Bitcraze instructions have been installed.
I get the following error when running setup.py py2exe :-
Any help would be greatly appreciated to allow me to make an installer.
MitchMan
Crazyflie 2.0
Crazyradio PA
CF LED-Ring Expansion
Breakout Expansion Board
Prototyping Expansion Board
Debug Adapter Kit
Sony Dual Shock 4
Re: py2exe error when trying to build Windows installer
This is a classical bug with py2exe/pyqt, the solution is to remove the folder port_v3 (the one indicated in the error message).
This happens because pyqt installs python3 packages in a python2 installation, which does not work when py2exe tries to load them.
Best regards,
Arnaud
MitchMan
Post by MitchMan »
Arnaud - Many thanks indeed, this has solved it!
MitchMan
Crazyflie 2.0
Crazyradio PA
Debug Adapter Kit
Sony Dual Shock 4
