soldering/desoldering help
jweather
Yikes, this thing is tiny! I've never tired to solder something so small. While trying to get my giant soldering iron tip in place to solder M1's wires, I managed to bridge 2-3 pins of the STM controller.
Any advice for removing the solder bridges without damaging the chip?
jtang613
Re: soldering/desoldering help
This sometimes happens when working in tight spaces (especially with an oversized iron/tip). First thing to do is locate a more appropriate soldering iron and/or tip, some (fine braid) solder wick and some liquid flux.
Then check out these videos:
https://www.youtube.com/watch?v=8yyUlABj29o
https://www.youtube.com/watch?v=eg2hxpy--gg
Find an older board, such as a spare nic or sound card to practice on first. Then dive in.
jtang613
Also, be sure to review the assembly instruction video here:
http://wiki.bitcraze.se/projects:crazyf ... s:assembly
jweather
Thanks... a smaller tip and some flux helped a lot to pull the extra solder out. Crazyflie works great, only problem now is my flying skills!
