[SOLVED]Battery/Link/Thrust/M1 bars skinny, no txt OSX 10.10
lxrocks
Post by lxrocks »
Marcus, as requested, creating topic for this.
So as per the screen capture, the cfclient looks ok except for the Battery/Link/Thrust and Motor meters which appear to be 'skinny' with no %progress text.
Running crazyflie-clients-python-2014.12.1 on MAC Yosemite 10.10.1, python2.7. The bars work fine on VM 0.5 and the same cfclient code on the mac shows 'skinny' progress bars.
Battery/Link meters not showing properly on MAC 10.10.1
I am not familiar with Qt but poking around it seems to me that this is not a bug, but QtProgressBar working as expected. According to the QtProgressBar documentation, 'MAC' style does not display text - http://pyqt.sourceforge.net/Docs/PyQt4/ ... ml#details The 'MAC' style seems to be a skinny bar only. Perhaps need to select a different style for MAC to see the %progress text.
The Qt experts might confirm this quicker than me.. :)
lxrocks
Re: Battery/Link/Thrust/M1 bars skinny, no % text Mac 10.10.
Post by lxrocks »
When I load menu.ui in QtDesigner on Linux, the Bars show correctly.
I downloaded QtDesigner for MAC, loaded menu.ui and it shows a skinny bar, so I am still tending towards a Style issue on the MAC. This is the first time I have looked at Qt before so I am fumbling a little trying to figure out how the Style works in designer.
Post by chad »
I'm fairly certain the "skinny" bars are an OS design change in Yosemite. Progress bars an similar UI affordances in iOS 8 and Yosemite have all taken on this skinny look. Personally, I'm not a fan but - eh whatever. Battery and Link text, IIRC, have never shown up on Mac OS X - again, likely an OS dependent issue since QT probably simply makes Cocoa calls to create these UI elements.
lxrocks
Post by lxrocks »
Chad,
I am sure you are right, I must admit, at first i was extremely irritated at the Yosemite L&F changes , but now I am used to it.
That said, I have figured out a way to fix this for Yosemite and learnt a little about the CF code and Qt on the way :) One can change ProgressBar styles in the code using CSS.
See code below crazyflie-clients-python/lib/cfclient/ui/main.py below - code inserted after self.setupUi(self) #line 100 .
(Source cloned from the git repo 11:30PM Jan 1, 2015 GMT/UTC)
#!/usr/bin/env python
# -*- coding: utf-8 -*-
#     ||          ____  _ __
#  +------+      / __ )(_) /_______________ _____  ___
#  | 0xBC |     / __  / / __/ ___/ ___/ __ `/_  / / _ \
#  +------+    / /_/ / / /_/ /__/ /  / /_/ / / /_/  __/
#   ||  ||    /_____/_/\__/\___/_/   \__,_/ /___/\___/
#  Copyright (C) 2011-2013 Bitcraze AB
#  Crazyflie Nano Quadcopter Client
#  This program is free software; you can redistribute it and/or
#  modify it under the terms of the GNU General Public License
#  as published by the Free Software Foundation; either version 2
#  of the License, or (at your option) any later version.
#  This program is distributed in the hope that it will be useful,
#  but WITHOUT ANY WARRANTY; without even the implied warranty of
#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
#  GNU General Public License for more details.
#  You should have received a copy of the GNU General Public License along with
#  this program; if not, write to the Free Software Foundation, Inc., 51
#  Franklin Street, Fifth Floor, Boston, MA  02110-1301, USA.
The main file for the Crazyflie control application.
__author__ = 'Bitcraze AB'
__all__ = ['MainUI']
import sys
import logging
logger = logging.getLogger(__name__)
from PyQt4 import QtGui, uic
from PyQt4.QtCore import pyqtSignal, Qt, pyqtSlot, QDir, QUrl
from PyQt4.QtGui import QLabel, QActionGroup, QMessageBox, QAction, QDesktopServices
from dialogs.connectiondialogue import ConnectDialogue
from dialogs.inputconfigdialogue import InputConfigDialogue
from dialogs.cf2config import Cf2ConfigDialog
from dialogs.cf1config import Cf1ConfigDialog
from dialogs.logconfigdialogue import LogConfigDialogue
from cfclient.utils.input import JoystickReader
from cfclient.utils.guiconfig import GuiConfig
from cfclient.utils.logconfigreader import LogConfigReader
from cfclient.utils.config_manager import ConfigManager
import cfclient.ui.toolboxes
import cfclient.ui.tabs
import cflib.crtp
from cflib.crazyflie.log import Log, LogVariable, LogConfig
from cfclient.ui.dialogs.bootloader import BootloaderDialog
from cfclient.ui.dialogs.about import AboutDialog
(main_window_class,
main_windows_base_class) = (uic.loadUiType(sys.path[0] +
                                           '/cfclient/ui/main.ui'))
class MyDockWidget(QtGui.QDockWidget):
    closed = pyqtSignal()
    def closeEvent(self, event):
        super(MyDockWidget, self).closeEvent(event)
        self.closed.emit()
class UIState:
    DISCONNECTED = 0
    CONNECTING = 1
    CONNECTED = 2
class MainUI(QtGui.QMainWindow, main_window_class):
    connectionLostSignal = pyqtSignal(str, str)
    connectionInitiatedSignal = pyqtSignal(str)
    batteryUpdatedSignal = pyqtSignal(int, object, object)
    connectionDoneSignal = pyqtSignal(str)
    connectionFailedSignal = pyqtSignal(str, str)
    disconnectedSignal = pyqtSignal(str)
    linkQualitySignal = pyqtSignal(int)
    _input_device_error_signal = pyqtSignal(str)
    _input_discovery_signal = pyqtSignal(object)
    _log_error_signal = pyqtSignal(object, str)
    def __init__(self, *args):
        super(MainUI, self).__init__(*args)
        self.setupUi(self)
        ### By lxrocks
        ### 'Skinny Progress Bar' tweak for Yosemite
        ### Tweak progress bar - artistic I am not - so pick your own colors !!!
        ### Only apply to Yosemite
        import platform
        if platform.system() == 'Darwin':
            (Version,junk,machine) =  platform.mac_ver()
            logger.info("This is a MAC - checking if we can apply Progress Bar Stylesheet for Yosemite Skinny Bars ")
            yosemite = (10,10,0)
            tVersion = tuple(map(int, (Version.split("."))))
            if tVersion >= yosemite:
                logger.info( "Found Yosemite:")
                tcss = """
                    QProgressBar {
                    border: 2px solid grey;
                    border-radius: 5px;
                    text-align: center;
                QProgressBar::chunk {
                     background-color: #05B8CC;
                self.setStyleSheet(tcss)
            else:
                logger.info( "Pre-Yosemite")
        self.cf = Crazyflie(ro_cache=sys.path[0] + "/cflib/cache",
                            rw_cache=sys.path[1] + "/cache")
        cflib.crtp.init_drivers(enable_debug_driver=GuiConfig()
                                                .get("enable_debug_driver"))
        # Create the connection dialogue
        self.connectDialogue = ConnectDialogue()
        # Create and start the Input Reader
        self._statusbar_label = QLabel("Loading device and configuration.")
        self.statusBar().addWidget(self._statusbar_label)
        self.joystickReader = JoystickReader()
        self._active_device = ""
        self.configGroup = QActionGroup(self._menu_mappings, exclusive=True)
        self._load_input_data()
        self._update_input
        ConfigManager().conf_needs_reload.add_callback(self._reload_configs)
        # Connections for the Connect Dialogue
        self.connectDialogue.requestConnectionSignal.connect(self.cf.open_link)
        self.connectionDoneSignal.connect(self.connectionDone)
        self.cf.connection_failed.add_callback(self.connectionFailedSignal.emit)
        self.connectionFailedSignal.connect(self.connectionFailed)
        self._input_device_error_signal.connect(self.inputDeviceError)
        self.joystickReader.device_error.add_callback(
                        self._input_device_error_signal.emit)
        self._input_discovery_signal.connect(self.device_discovery)
        self.joystickReader.device_discovery.add_callback(
                        self._input_discovery_signal.emit)
        # Connect UI signals
        self.menuItemConnect.triggered.connect(self.connectButtonClicked)
        self.logConfigAction.triggered.connect(self.doLogConfigDialogue)
        self.connectButton.clicked.connect(self.connectButtonClicked)
        self.quickConnectButton.clicked.connect(self.quickConnect)
        self.menuItemQuickConnect.triggered.connect(self.quickConnect)
        self.menuItemConfInputDevice.triggered.connect(self.configInputDevice)
        self.menuItemExit.triggered.connect(self.closeAppRequest)
        self.batteryUpdatedSignal.connect(self.updateBatteryVoltage)
        self._menuitem_rescandevices.triggered.connect(self._rescan_devices)
        self._menuItem_openconfigfolder.triggered.connect(self._open_config_folder)
        self._auto_reconnect_enabled = GuiConfig().get("auto_reconnect")
        self.autoReconnectCheckBox.toggled.connect(
                                              self._auto_reconnect_changed)
        self.autoReconnectCheckBox.setChecked(GuiConfig().get("auto_reconnect"))
        # Do not queue data from the controller output to the Crazyflie wrapper
        # to avoid latency
        #self.joystickReader.sendControlSetpointSignal.connect(
        #                                      self.cf.commander.send_setpoint,
        #                                      Qt.DirectConnection)
        self.joystickReader.input_updated.add_callback(
                                         self.cf.commander.send_setpoint)
        # Connection callbacks and signal wrappers for UI protection
        self.cf.connected.add_callback(
                                              self.connectionDoneSignal.emit)
        self.cf.disconnected.add_callback(self.disconnectedSignal.emit)
        self.disconnectedSignal.connect(
                        lambda linkURI: self.setUIState(UIState.DISCONNECTED,
                                                        linkURI))
        self.cf.connection_lost.add_callback(self.connectionLostSignal.emit)
        self.connectionLostSignal.connect(self.connectionLost)
        self.cf.connection_requested.add_callback(
                                         self.connectionInitiatedSignal.emit)
        self.connectionInitiatedSignal.connect(
                           lambda linkURI: self.setUIState(UIState.CONNECTING,
                                                           linkURI))
        self._log_error_signal.connect(self._logging_error)
        # Connect link quality feedback
        self.cf.link_quality_updated.add_callback(self.linkQualitySignal.emit)
        self.linkQualitySignal.connect(
                   lambda percentage: self.linkQualityBar.setValue(percentage))
        # Set UI state in disconnected buy default
        self.setUIState(UIState.DISCONNECTED)
        # Parse the log configuration files
        self.logConfigReader = LogConfigReader(self.cf)
        # Add things to helper so tabs can access it
        cfclient.ui.pluginhelper.cf = self.cf
        cfclient.ui.pluginhelper.inputDeviceReader = self.joystickReader
        cfclient.ui.pluginhelper.logConfigReader = self.logConfigReader
        self.logConfigDialogue = LogConfigDialogue(cfclient.ui.pluginhelper)
        self._bootloader_dialog = BootloaderDialog(cfclient.ui.pluginhelper)
        self._cf2config_dialog = Cf2ConfigDialog(cfclient.ui.pluginhelper)
        self._cf1config_dialog = Cf1ConfigDialog(cfclient.ui.pluginhelper)
        self.menuItemBootloader.triggered.connect(self._bootloader_dialog.show)
        self._about_dialog = AboutDialog(cfclient.ui.pluginhelper)
        self.menuItemAbout.triggered.connect(self._about_dialog.show)
        self._menu_cf2_config.triggered.connect(self._cf2config_dialog.show)
        self._menu_cf1_config.triggered.connect(self._cf1config_dialog.show)
        # Loading toolboxes (A bit of magic for a lot of automatic)
        self.toolboxes = []
        self.toolboxesMenuItem.setMenu(QtGui.QMenu())
        for t_class in cfclient.ui.toolboxes.toolboxes:
            toolbox = t_class(cfclient.ui.pluginhelper)
            dockToolbox = MyDockWidget(toolbox.getName())
            dockToolbox.setWidget(toolbox)
            self.toolboxes += [dockToolbox, ]
            # Add menu item for the toolbox
            item = QtGui.QAction(toolbox.getName(), self)
            item.setCheckable(True)
            item.triggered.connect(self.toggleToolbox)
            self.toolboxesMenuItem.menu().addAction(item)
            dockToolbox.closed.connect(lambda: self.toggleToolbox(False))
            # Setup some introspection
            item.dockToolbox = dockToolbox
            item.menuItem = item
            dockToolbox.dockToolbox = dockToolbox
            dockToolbox.menuItem = item
        # Load and connect tabs
        self.tabsMenuItem.setMenu(QtGui.QMenu())
        tabItems = {}
        self.loadedTabs = []
        for tabClass in cfclient.ui.tabs.available:
            tab = tabClass(self.tabs, cfclient.ui.pluginhelper)
            item = QtGui.QAction(tab.getMenuName(), self)
            item.toggled.connect(tab.toggleVisibility)
            self.tabsMenuItem.menu().addAction(item)
            tabItems[tab.getTabName()] = item
            self.loadedTabs.append(tab)
            if not tab.enabled:
                item.setEnabled(False)
        # First instantiate all tabs and then open them in the correct order
        try:
            for tName in GuiConfig().get("open_tabs").split(","):
                t = tabItems[tName]
                if (t != None and t.isEnabled()):
                    # Toggle though menu so it's also marked as open there
                    t.toggle()
        except Exception as e:
            logger.warning("Exception while opening tabs [%s]", e)
    def setUIState(self, newState, linkURI=""):
        self.uiState = newState
        if (newState == UIState.DISCONNECTED):
            self.setWindowTitle("Not connected")
            self.menuItemConnect.setText("Connect to Crazyflie")
            self.connectButton.setText("Connect")
            self.menuItemQuickConnect.setEnabled(True)
            self.batteryBar.setValue(3000)
            self._menu_cf2_config.setEnabled(False)
            self.linkQualityBar.setValue(0)
            self.menuItemBootloader.setEnabled(True)
            self.logConfigAction.setEnabled(False)
            if (len(GuiConfig().get("link_uri")) > 0):
                self.quickConnectButton.setEnabled(True)
        if (newState == UIState.CONNECTED):
            s = "Connected on %s" % linkURI
            self.setWindowTitle(s)
            self.menuItemConnect.setText("Disconnect")
            self.connectButton.setText("Disconnect")
            self.logConfigAction.setEnabled(True)
            self._menu_cf2_config.setEnabled(True)
        if (newState == UIState.CONNECTING):
            s = "Connecting to %s ..." % linkURI
            self.menuItemConnect.setText("Cancel")
            self.connectButton.setText("Cancel")
            self.quickConnectButton.setEnabled(False)
            self.menuItemBootloader.setEnabled(False)
            self.menuItemQuickConnect.setEnabled(False)
    @pyqtSlot(bool)
    def toggleToolbox(self, display):
        menuItem = self.sender().menuItem
        dockToolbox = self.sender().dockToolbox
        if display and not dockToolbox.isVisible():
            dockToolbox.widget().enable()
            self.addDockWidget(dockToolbox.widget().preferedDockArea(),
                               dockToolbox)
            dockToolbox.show()
        elif not display:
            dockToolbox.widget().disable()
            self.removeDockWidget(dockToolbox)
            dockToolbox.hide()
            menuItem.setChecked(False)
    def _rescan_devices(self):
        self._statusbar_label.setText("No inputdevice connected!")
        self._menu_devices.clear()
        self.joystickReader.stop_input()
        for c in self._menu_mappings.actions():
            c.setEnabled(False)
        devs = self.joystickReader.getAvailableDevices()
        if (len(devs) > 0):
            self.device_discovery(devs)
    def configInputDevice(self):
        self.inputConfig = InputConfigDialogue(self.joystickReader)
        self.inputConfig.show()
    def _auto_reconnect_changed(self, checked):
        self._auto_reconnect_enabled = checked
        GuiConfig().set("auto_reconnect", checked)
        logger.info("Auto reconnect enabled: %s", checked)
    def doLogConfigDialogue(self):
        self.logConfigDialogue.show()
    def updateBatteryVoltage(self, timestamp, data, logconf):
        self.batteryBar.setValue(int(data["pm.vbat"] * 1000))
    def connectionDone(self, linkURI):
        self.setUIState(UIState.CONNECTED, linkURI)
        GuiConfig().set("link_uri", linkURI)
        lg = LogConfig("Battery", 1000)
        lg.add_variable("pm.vbat", "float")
        self.cf.log.add_config(lg)
        if lg.valid:
            lg.data_received_cb.add_callback(self.batteryUpdatedSignal.emit)
            lg.error_cb.add_callback(self._log_error_signal.emit)
            lg.start()
        else:
            logger.warning("Could not setup loggingblock!")
    def _logging_error(self, log_conf, msg):
        QMessageBox.about(self, "Log error", "Error when starting log config"
                " [%s]: %s" % (log_conf.name, msg))
    def connectionLost(self, linkURI, msg):
        if not self._auto_reconnect_enabled:
            if (self.isActiveWindow()):
                warningCaption = "Communication failure"
                error = "Connection lost to %s: %s" % (linkURI, msg)
                QMessageBox.critical(self, warningCaption, error)
                self.setUIState(UIState.DISCONNECTED, linkURI)
        else:
            self.quickConnect()
    def connectionFailed(self, linkURI, error):
            msg = "Failed to connect on %s: %s" % (linkURI, error)
            QMessageBox.critical(self, warningCaption, msg)
        else:
            self.quickConnect()
        self.hide()
        self.cf.close_link()
        GuiConfig().save_file()
    def connectButtonClicked(self):
        if (self.uiState == UIState.CONNECTED):
        elif (self.uiState == UIState.CONNECTING):
        else:
            self.connectDialogue.show()
    def inputDeviceError(self, error):
        QMessageBox.critical(self, "Input device error", error)
    def _load_input_data(self):
        # Populate combo box with available input device configurations
        for c in ConfigManager().get_list_of_configs():
            node = QAction(c,
                           checkable=True,
                           enabled=False)
            node.toggled.connect(self._inputconfig_selected)
            self.configGroup.addAction(node)
            self._menu_mappings.addAction(node)
    def _reload_configs(self, newConfigName):
        # remove the old actions from the group and the menu
        for action in self._menu_mappings.actions():
            self.configGroup.removeAction(action)
        self._menu_mappings.clear()
        # reload the conf files, and populate the menu
        self._update_input(self._active_device, newConfigName)
    def _update_input(self, device="", config=""):
        self._active_config = str(config)
        self._active_device = str(device)
        GuiConfig().set("input_device", self._active_device)
        GuiConfig().get(
                     "device_config_mapping"
                     )[self._active_device] = self._active_config
        self.joystickReader.start_input(self._active_device,
                                       self._active_config)
        # update the checked state of the menu items
            c.setEnabled(True)
            if c.text() == self._active_config:
                c.setChecked(True)
        for c in self._menu_devices.actions():
            c.setEnabled(True)
            if c.text() == self._active_device:
                c.setChecked(True)
        # update label
        if device == "" and config == "":
            self._statusbar_label.setText("No input device selected")
        elif config == "":
            self._statusbar_label.setText("Using [%s] - "
                                          "No input config selected" %
                                          (self._active_device))
        else:
            self._statusbar_label.setText("Using [%s] with config [%s]" %
                                           self._active_config))
    def _inputdevice_selected(self, checked):
        if (not checked):
            return
        sender = self.sender()
        self._active_device = sender.text()
        device_config_mapping = GuiConfig().get("device_config_mapping")
        if (self._active_device in device_config_mapping.keys()):
            self._current_input_config = device_config_mapping[
                str(self._active_device)]
        else:
            self._current_input_config = self._menu_mappings.actions()[0].text()
        GuiConfig().set("input_device", str(self._active_device))
            if (c.text() == self._current_input_config):
                c.setChecked(True)
        self.joystickReader.start_input(str(sender.text()),
        self._statusbar_label.setText("Using [%s] with config [%s]" % (
                                      self._current_input_config))
    def _inputconfig_selected(self, checked):
        if (not checked):
            return
        self._update_input(self._active_device, self.sender().text())
    def device_discovery(self, devs):
        group = QActionGroup(self._menu_devices, exclusive=True)
        for d in devs:
            node = QAction(d["name"], self._menu_devices, checkable=True)
            node.toggled.connect(self._inputdevice_selected)
            group.addAction(node)
            self._menu_devices.addAction(node)
            if (d["name"] == GuiConfig().get("input_device")):
                self._active_device = d["name"]
        if (len(self._active_device) == 0):
            self._active_device = self._menu_devices.actions()[0].text()
        if (device_config_mapping):
            else:
        else:
        # Now we know what device to use and what mapping, trigger the events
        # to change the menus and start the input
            c.setEnabled(True)
                c.setChecked(True)
            if (c.text() == self._active_device):
                c.setChecked(True)
    def quickConnect(self):
        try:
            self.cf.open_link(GuiConfig().get("link_uri"))
        except KeyError:
            self.cf.open_link("")
    def _open_config_folder(self):
        QDesktopServices.openUrl(QUrl("file:///" + QDir.toNativeSeparators(sys.path[1])))
    def closeAppRequest(self):
        self.close()
        sys.exit(0)
Post by chad »
Awesome!! I like that soooo much better!!
Maybe you'll want to fork the repository, make the change and create a pull request so Bitcraze can take the change if they like it. I think I'll definately apply it to the fork I commonly use.
Nice job!! :ugeek:
lxrocks
Post by lxrocks »
Thanks Chad,
I'm not familiar with Git or process/etiquette for submitting code to Crazyflie repositories.
Perhaps you can point me to a docco somewhere I can read :)
EDIT: Ok - I have registered with Github and will follow the tutorials provided for forking & pull requests.
lxrocks
Post by lxrocks »
Chad,
I have created the fork , added my code and put the pull request in.
Github have a great tool for the MAC which made the process fairly straightforward
