Issue with radio under Windows 7 64bit
Vertikar
Post by Vertikar »
So I've succesfully connected and tested my crazyflie on a few 32bit machines, but I'm not having any luck on any of my 64bit ones.
Radio won't show up under connect, and if I try the bootloader trick I get this
alex
Re: Problems installing PyUSB and running CF PC Client
Post by alex »
I'm running the Crazyradio successfully under Win7 Home Premium x64. Did you install the USB driver from the wiki?
Vertikar
Re: Issue with radio under Windows 7 64bit
Post by Vertikar »
alex wrote:I'm running the Crazyradio successfully under Win7 Home Premium x64. Did you install the USB driver from the wiki?
Yeah, got the driver installed. Have tried re-installing the client software as well.
Vertikar wrote: Yeah, got the driver installed. Have tried re-installing the client software as well.
Did you manage to solve this? If not, could you try inserting the dongle into a different USB port?
/Marcus
Vertikar
Post by Vertikar »
/Marcus
Just tried another couple of USB ports, no difference.
