[SOLVED] Axis take about 2 seconds to settle after landing
Call_me_a_Cab
Post by Call_me_a_Cab »
Hi guys Merry Christmas!!
Having just started flying, my roll trim needs to be at 11 to fly straight up and when I land, the roll axis on the client telemetry takes around two seconds to level out.
I can post a vid if needed?
Is this normal?
Re: Roll Axis take about 2 seconds to settle after landing
Have you tried balancing the propellers? This sounds like a typical vibration issue. See this post as well.
Call_me_a_Cab
Thanks Tobias,
To be fair... No I haven't It would of been my first point of call but the telemetry is still unstable for around 1 second or more after the props have stopped spinning so I got scared and posted.
I will try and then reply. thanks
I've seen the same thing with vibration issues so I think that will fix it.
Call_me_a_Cab
Fixed It!!
Thanks and sorry for not trying that before posting!
I used nail varnish instead of tape to balance the props - I found that eaiser
