Crazyflie 2.0 turns off when motors start
dbrgn
Post by dbrgn »
I can start my Crazyflie 2.0 just fine, the self test works. All LEDs light up as they should.
But when adding thrust, the flie immediately turns off.
https://www.youtube.com/watch?v=LSJgYeyAhiM
Is this some kind of short-circuit? Or is that the issue that was addressed in the firmware update?
The other Crazyflie 2.0 I received works fine.
Re: Crazyflie 2.0 turns off when motors start
Post by chad »
This might be fixed in a firmware checkin... Here's the blog post and the official release.
I would say it is a combination of the bug we fixed with the firmware Chad pointed out and maybe a depleted battery.
If you have the time, please give us feedback on how the update progress worked.
dbrgn
Post by dbrgn »
Tobias, yes, I'll do that. But for the firmware upgrade first I'll have to get the current cfclient to work (see support issue regarding the segfaults) :)
Yep, Marcus is working on it. Switching to SDL2 might not have been the best thing at this moment...
One good thing though is that you don't need the cfclient for the DFU update, v2014.12.0. The instructions are in the readme file in the zip.
dbrgn
Post by dbrgn »
I'll try the DFU update tonight and will let you know.
dbrgn
Post by dbrgn »
Awesome, the firmware upgrade helped!And the DFU upgrade is almost easier than via cfclient :)
Just a tip dbrgn. If you have the Cazyradio you can flash it directly from the build environment with "make cload". Instructions here, that is very convenient when developing.
dbrgn
Post by dbrgn »
tobias wrote:Just a tip dbrgn. If you have the Cazyradio you can flash it directly from the build environment with "make cload". Instructions here, that is very convenient when developing.
Yay, that's great :) Thanks.
Post by chad »
This was news to me! But I like it. :D
