The easiest and best Controller
What is the easiest and most simple joystick (Controller)?
Xbox 360 Controller
1
6%
Xbox ONE Controller
0
No votes
PS3 Controller
12
75%
PS4 Controller
3
19%
Total votes: 16
idreams
Post by idreams »
I am a beginner.
I want to buy a controller for crazyflie.
1. Xbox 360 Controller
2. Xbox ONE Controller
3. PS3 Controller
4. PS4 Controller
Thanks.
Crazyflie 2.0 + Crazyradio PA + Debug Adapter and LED Deck.
Re: The easiest and best Controller
Post by chad »
I think all four choices work equally as well and it really just comes down to what you're most comfortable with. Sometimes that's just a function of what gaming system you've used the most... In that regard, I'm partial to the PS3 controller.
idreams
Post by idreams »
chad wrote:I think all four choices work equally as well and it really just comes down to what you're most comfortable with. Sometimes that's just a function of what gaming system you've used the most... In that regard, I'm partial to the PS3 controller.
Thanks chad.
ion
Post by ion »
I went out and bought an Xbox One controller and bought a PS4 bundle, turns out I prefer the ps4 controller because the triggers seem easier (for me) to use for throttle. Xbox One sticks are somewhat more sensitive and I get unnecessary roll/pitch when I just rest my fingers on them.
That could be me, but I'd like to point it out.
idreams
Post by idreams »
ion wrote:I went out and bought an Xbox One controller and bought a PS4 bundle, turns out I prefer the ps4 controller because the triggers seem easier (for me) to use for throttle. Xbox One sticks are somewhat more sensitive and I get unnecessary roll/pitch when I just rest my fingers on them.
Thank you ion ;)
dbrgn
Post by dbrgn »
I have the Logitech Rumble Gamepad F510. Works nicely, also from Linux. You can put it into either Xinput mode or DirectInput mode.
I'm partial to the PS3 controller since I've been using it ever since we flew the first Crazyflie prototype. The PS4 is also good, but I'm not a big fan of the original Xbox controller (haven't tested the other ones). The analog axis is stiff and not centered when you release the sticks, but that could just be the one we have at the office ;) Initially we were using mix of PS3/Xbox controllers, since we had different gaming consoles at home. But after a while we all switched to the PS3 controller.
rebit
Post by rebit »
hoverbear
Post by hoverbear »
marcus wrote:I'm partial to the PS3 controller since I've been using it ever since we flew the first Crazyflie prototype. The PS4 is also good, but I'm not a big fan of the original Xbox controller (haven't tested the other ones). The analog axis is stiff and not centered when you release the sticks, but that could just be the one we have at the office ;) Initially we were using mix of PS3/Xbox controllers, since we had different gaming consoles at home. But after a while we all switched to the PS3 controller.
I have a pair of Xbox 360 controllers and they are quite bad for this. Idling my sticks can read over 30%.
codeman
Post by codeman »
i got a PS3 compatible and it works great out of the box!
