I have a problem with VMWare player/VertualBox. , my OS is (Windows 8 Pro) there is a conflict between Hyper-V and VM machine, I need Hyper-V to Run Windows phone SDK so it is not a solution to remove it, my question is, is there is any solution to work around this problem??
Please advice and thank you in advance.
Hyper-V
Re: Hyper-V
You could try to import the virtual-machine in Hyper-V, apparently there is some way to do it: https://social.technet.microsoft.com/Fo ... nd-hyper-v
Tell us if it works.
chonchonchon
Re: Hyper-V
Do you need Hyper-V and VM in the same project ?
If you use them in different project, simple workaround is to use different windows profile
Create 2 different users on windows.
user 1 = Hyper-V + SDK
user 2 = VM
When login in a user, only it's software will be loaded.
You MUST Deinstall and Resinstall each software using dedicated user (do not use admin)
Backup your project before playing with windows profile
user 2 = VM
