Cutting Motor Wires
bstott
Cutting Motor Wires
Post by bstott »
I'd like to cut the motor wires to remove some of the excess length. Is there a problem created within your allowance for resistance or anything other which would prohibit my shortening the motor wires?
Or would there be a problem caused if I wound the excess motor wire length around the individual arms?
Thanks.
ross123540
Re: Cutting Motor Wires
Post by ross123540 »
Cutting the motor wires should not cause any issue electrically, but it dose seem better in my limited experience to have a little bit of play in the wires as they seem to get damaged quite easily as the plastic sheath is of a soft compound.
rene_canlas
Cutting Motor Wires
Post by rene_canlas »
I shortened the wires a bit so i didn't have wrap them or have them dangling. I left some allowance for flexibility so that the wires don't get stressed during crashes.
Sent from my iPad using Tapatalk
