pyUSB incompatibility?
itsnotmyfault
Post by itsnotmyfault »
While Using omwdunkley's https://bitbucket.org/bitcraze/crazyflie-pc-client I ran into a problem on linux, where I was getting a message complaining that I was using too many arguments.
"TypeError: write() takes at most 4 arguments (5 given)"
Others may be running into the same issue with pyUSB
The solution is to go into
/crazyflie-pc-client/lib/cflib/drivers/crazyradio.py line 245, 246
#remove third argument 0 for both read and write. similar to an issue in https://bitbucket.org/benallard/galileo ... t-10892785
Hope this helps someone else.
